Suggestions for a rough running 00 ap1
Old Jun 9, 2018 | 09:34 AM
JonC's Avatar
Originally Posted by tx_s2k
little update. Driving on it for a couple of days no change. Tps showed a negative value at idle and not full 100% at full throttle. Car still reaks of fuel at idle. So I'm stumped. Injectors or tps?
Where is the fuel smell coming from?
Old Jun 9, 2018 | 10:09 AM
tx_s2k's Avatar
Inside and outside. Start it walk away and come back and I can smell it
Old Jun 9, 2018 | 10:15 AM
JonC's Avatar
Is it coming from under the hood? Gas cap? Fumes from exhaust?
Is it possible you have a leaky injector o-ring?
Old Jun 9, 2018 | 11:02 AM
tx_s2k's Avatar
I'm not sure about the engine. Gas cap was just tested today during inspection. Exhaust and in the cabin is where I normally smell it
Old Jun 9, 2018 | 04:57 PM
tx_s2k's Avatar
Pulled the plugs after sticking a screwdriver to the injector body. I didn't really hear any out of the ordinary firing. Could it still be stuck open? If so what would it sound Like? 2 and 3 kinda smelt like fuel but not a hardcore smell. I put them in my hands according to how I pulled them out.
Old Jun 10, 2018 | 03:06 AM
JonC's Avatar
Are you getting spark on all 4 cylinders? No spark or too much fuel could be happening. If no spark, maybe coilpack fried? If too much fuel maybe injector stuck open?
Old Jun 10, 2018 | 05:41 AM
tx_s2k's Avatar
I've got new coil packs on order. No real sure how to tell if injector is.stuck open.
Old Jun 10, 2018 | 07:50 AM
tx_s2k's Avatar
Update. Did a compression test 1-205 2-210 3-210 4-210. Still getting smelly plugs and exhaust. Going to go ahead and replace injectors since it's so cheap. Car has 197k
Old Jun 10, 2018 | 09:58 AM
gptoyz's Avatar
If it's running like shit at idle, assuming your spark system is running nominally then your injectors can be leaking.
You can also see if the engine is trimming the hell out of the fuel on short term fuel trims via OBD2
Old Jun 10, 2018 | 10:30 AM
Jah2000's Avatar
Perhaps the TCT? My car runs a lot better and smoother with Billman's TCT. ...like a different engine in it now.
Before I installed the new TCT.. I never/rarely used AC, because it bogged my engine coming to a stop and made it runs super crappy and slow. Now, it seems that the TCT fixed that.
Also, I've heard about clogged and old cats affecting performance a lot and messing with fuel mixtures (especially since a lot of S2ks are high mileage nowadays). Irdk how to tell if one's catalytic converter needs replacing or not though (I'm still on my original cat at 115k miles).
