Suggestions for a rough running 00 ap1
Old Aug 12, 2018 | 09:34 AM
  #21
Snakecharmer's Avatar
I had an idle problem where revs dropped to around 600 and the engine shook for a second before returning back to idle. A new air filter sorted that. My short term fuel trim still shows around -7 % but the car goes well. Have you looked at your fuel pressure regulator? If you are weeping fuel into the vacuum pipe your diaphragm has failed and could be the source of your leak. Fuel trims would be positive if fuel pressure was down.
Old Aug 12, 2018 | 10:41 AM
  #22
outeiroj's Avatar
Did you verify there are no vacuum leaks? Have you pulled the vacuum line off the fpr to see if it runs better unplugged?
Phill24
Oct 28, 2012 08:24 AM
RobEvo5
Dec 28, 2010 11:09 AM
ABCVTEC
Aug 17, 2009 10:32 PM
jari8378
13
Oct 28, 2007 10:19 AM
facets
Jan 22, 2004 08:21 AM
