Supercharger Issue/MAP/ESM
Old Sep 18, 2002 | 05:05 AM
Yellow Streak's Avatar
Default Supercharger Issue/MAP/ESM
Guys-
I am chasing a problem with my Comptech SC and am looking for some input. My car is not making the horsepower it should and I am hoping to be able to resolve the issue that is limiting me.
I went out for a test drive with the mechanic and he used a Snap-On computer hooked to the OBD-II jack to monitor a few things. Here are two observations that he made:
1. The MAP reading (In.Hg) started around 6 and went to 29.9 under WOT acceleration.
2. The timing went from 44.5 degrees advanced to 14.5 degrees advanced.
My questions are:
1. Shouldn't the reading from the MAP be going down (as in there is less vacuum as the engine winds up)?
2. Isn't 30 degrees a lot of timing for the car to back out?
Thanks in advance for any help you can offer.
-YS
Old Sep 18, 2002 | 07:07 AM
koejing's Avatar
1. Your MAP sensor is functioning properly. It is going from a closed-throttle, vacuum condition (6 inHg ~ 0.2 ATM) to a WOT, atmospheric condition (29.9 inHg ~ 1 ATM). Your assumption that there should be less vacuum at WOT is supported by these #'s.
What kind of HP is the car making? Have you checked the A/F ratio? VAFC installed? Any drivability probs?
koejing
Old Sep 18, 2002 | 07:15 AM
[QUOTE]Originally posted by koejing
[B]1.
Old Sep 18, 2002 | 07:28 AM
[QUOTE]Originally posted by hecash
[B]I'm not sure that there is enough information here to lead to the cause.
Has your tuner got the extra Honda error codes for the S2000 in his scanner?
Old Sep 18, 2002 | 08:02 AM
[B]I don't understand the "rich" situation.
JoeyBalls
Oct 22, 2008 04:54 PM
jjjsantos
Feb 11, 2008 01:06 PM
CKit
Aug 30, 2007 09:17 PM
CKit
Aug 30, 2007 08:21 PM
CKit
Jun 6, 2007 03:14 PM
