Swapped Fuel pump but...
Old Oct 29, 2006 | 02:21 AM
JToolz's Avatar
Default Swapped Fuel pump but...
Ok my 2000 s2000 wont start. I suspected fuel since I check and the car was sparking. I could spray starter fluid into the throttle body and it would start up and sputter but then die. I proceeded to swap out the fuel pump but the car still just doesnt want to start. Im not sure what it could be. Any suggestions?
Old Oct 29, 2006 | 05:28 AM
Slows2k's Avatar
You need to troubleshoot why you don't have any fuel pressure. There is wiring to the pump and a relay in the circuit.
Old Oct 29, 2006 | 06:19 AM
Ek9's Avatar
Ek9
Banned
My god man! You replaced the pump without checking the wiring?
The PGM-FI relay and the immobiliser are both things I'd check before I did fuel pump. You really should have thrown a volt meter on the input wires to the pump. No 12V = no fuel pressure.
Before I replaced the pump, I'd try hot wiring it to see if the engine runs, then you know it's a wiring problem.
Old Nov 6, 2006 | 06:11 AM
Widebodys2k's Avatar
Id try listening for the fuel pump to prime, if it dosnt check your wiring/fuses, next i would look into your injecters, are they after market?
Old Nov 6, 2006 | 09:48 AM
mxt_77's Avatar
Please tell me that you at least checked the fuse before replacing the whole pump.
aero3685
Sep 3, 2023 08:34 AM
LordSovereign
May 27, 2015 12:30 PM
Luis06s2k
Forced Induction For Sale
Mar 26, 2011 09:11 PM
Spec_Ops2087
May 18, 2010 01:58 PM
