Swerving Accel/Deccel problems
Old Sep 23, 2010 | 10:57 PM
1point3_to_2point2's Avatar
Default Swerving Accel/Deccel problems
im having problem with my car and i cant figure out what it is
more noticeable at higher speeds
when i start driving and i step on gas the car kind of jerks to the right
when i let off the gas after moderate acceleration the car jerks back to left
so far ive checked
tires pressures
alignment
and brand new tires (all same age)
1 more thing to add...i recently bent a front right rim pretty badly but not sure how
Old Sep 24, 2010 | 07:50 AM
any ideas
Old Sep 24, 2010 | 07:53 AM
HiRpmVTEC's Avatar
Has it just starting doing this or did it gradually get worse?
Old Sep 24, 2010 | 08:16 AM
idea-catalyst's Avatar
A friend of mine had an old Volvo in high school that did exactly that. We laughed that he could change lanes by simply accelerating or decelerating. His was a rear-suspension problem and yours sounds just like it. Acceleration and deceleration forces may be causing your rear suspension to shift. From your description, it sounds like your left rear suspension is loose. When you accelerate, the force being applied by the rear wheels puts rearward pressure on the suspension. If the left side shifts back slightly, it would cause there to be a steering effect from the rear wheels, moving you to the right. The reverse is true when you decelerate or brake.
While there may be a different explanation to what you are experiencing, I'd sure check out the rear suspension. Sounds scary.
Old Sep 24, 2010 | 08:35 AM
Old Sep 24, 2010 | 08:36 AM
it got better after alignment and new tires but i still can feel it
Old Sep 24, 2010 | 08:37 AM
archs2000's Avatar
i know you said you checked tire pressure, but for good measure i would double check the rear. It's pretty finicky.
Old Sep 24, 2010 | 08:46 AM
HiRpmVTEC's Avatar
check control arm and supporting parts
Old Sep 24, 2010 | 10:09 AM
TonysMI4's Avatar
so far ive checked
tires pressures
alignment
Don't worrie about this. Its over-steer or under-steer from what iv read. AP1 has over-steer and ap2 has under-steer. Mine does it to. At first i thought i was going crazy. The car does that on its own. I dont like it but its just what it is.
Old Sep 24, 2010 | 01:01 PM
ahrmike's Avatar
wrong info..
