Synchros gone bad? What pn's do i need?
I've run into a problem which has me suspecting bad synchros.
A few months ago I changed out the transmission fluid in my AP1, in my lack of foresight, I put in some regular shell gear oil. Soon after, I noticed I could no longer downshift into 2nd gear and had to come to an almost complete stop in order to get into 1st, even if I rev-match. I discovered I could only get into 2nd gear if I double-clutched and quickly rev-matched, and even then the shift was a notchy.
Other than that the transmission rows through all the gears just fine.
Does this look like a synchro issue, or simply change the fluid back to Honda MTF and be done with it?
And if it is synchros, which pn's do I need for the rebuild?
I found the gear set from honda's website
PN: 23432-PCY-306
What else would I need?
PN: 23432-PCY-306
check the label of the gear oil you used, if it is a GL-5 fluid and it contains sulphur I'd seriously consider flushing the tranny by doing a fill and drain prior to the final fill of Honda MTF. You want to get out as much sulphur as possible as that's what hurts brass syncros.
