2nd gear grind?
Old Jun 9, 2007 | 06:24 PM
minh's Avatar
Default 2nd gear grind?
i would occasionally grind 2nd gear when accelerating and fast shifting (usually in vtec)
anyone know whats up? it really bugs me
Old Jun 9, 2007 | 06:36 PM
Silverstreak HX's Avatar
I think this means you need to change your transmission fluid. Did mine this year at around 5500 miles because my 2nd gear was getting kinda notchy. Used the new improved Honda MTF and am Amazed at how much smoother it is . Smoother than when it was new. Try it!
Old Jun 9, 2007 | 06:40 PM
minh's Avatar
i took the car in for a trans fluid change last september...which is 17,000 miles ago...is it time for another change? i thought it would last longer than that?
Old Jun 9, 2007 | 08:10 PM
2slow's Avatar
It's a very common problem with the AP1 transmission. Mine got so bad I started losing gears. Fortunately for me, Hondacare paid to rebuild my tranny--but it wasn't easy.
Do a search for 1st-2nd grind and you'll find all kinds of suggestions on how to make it a little better without paying for a rebuild (e.g. change fluid, change shifting technique, change the way you hold your knob...blah, blah, blah). Most will probably not work, but it's worth a shot. The first thing, however, should be to change your tranny fluid. It helped me a little at first, but 1000 miles later, gears were excessively grinding again.
If nothing helps, and your car is still under warranty, you can try getting the dealership to fix it. However, they will most likely tell you there's nothing wrong and send you home. But, at least you will have a record that you complained about it in case it gets worse down the road.
Old Jun 10, 2007 | 06:52 AM
clawhammer's Avatar
After 17000 miles, I would definitely get the fluid changed.
Old Jun 10, 2007 | 07:37 AM
JPRICE!'s Avatar
i have the same problem...if i shift at like 8500 it grinds but at like 8200 it doesnt so i just shift there...only 1st to 2nd will grind for me i can rev bounce 2nd to 3rd gear and no grind i havent tried changin my tranny fluid yet tho
ekid1314
Mar 22, 2013 12:26 PM
calvinnnnn
Nov 29, 2011 10:31 PM
stafaa
Aug 16, 2011 05:15 PM
tronvex
Nov 10, 2008 07:39 PM
Destiny2002
Feb 12, 2003 07:12 AM
