Taking out helper spring?
Old Jul 10, 2002 | 04:37 PM
usual_suspect's Avatar
Default Taking out helper spring?
I have Tein RS coilovers and was wondering what would happen if you took out the helper springs? Would performance be compromised? Would the car be able to drop even lower? Thanks.
Old Jul 10, 2002 | 04:48 PM
RT's Avatar
RT
I don't know about the Tein RS specifically, but in general the "Tender" springs are there to keep the main spring from dropping out of the cups when the suspension is extended. They are a relatively low spring rate and should be pretty much blocked-up with the weight of the car alone so it shouldn't matter to performance. Why would you want to pull them? Are you not able to lower the car enough w/ the perches and/or mounts?
Old Jul 10, 2002 | 04:51 PM
Yes, mainly i wanted the car to go a little lower. Is this possible?
Old Jul 10, 2002 | 08:50 PM
RT's Avatar
RT
I'd be scared the springs would come out of the cup ...... unless you adjusted the preload high enough to keep the springs seated......but then the car wouldn't be low enough again.
I don't know, I'd be scared ...... you sure you can't go lower on either the preload or the ride height adjustment? The RS's do both don't they?
Old Jul 10, 2002 | 10:15 PM
Hams2000's Avatar
Dont forget the stroke on the shock will be much shorter than intended and your handling will probably be comprimised...
chris
bluemetals2k
Jan 24, 2011 03:29 PM
bluemetals2k
Jan 23, 2011 07:56 PM
ash2k
Aug 7, 2010 02:29 PM
kikicha
Jan 11, 2007 10:17 PM
WyattH
May 5, 2005 08:05 PM
