tips for adding AEM cai??
hey guys,
just ordered a new AEM CAI and plan on doing an install this weekend with the help of Macgyver (thxs man) . Do i need anything in addition to the aem kit?
Just want to make sure i have everything so that we don't have to run out.. ir ty wraps, screws, dremmal, etc??
Plus do you have any time saving tips and tricks?
Thxs all
Bass
Thxs all
Bass
It is pretty simple, a sharp box cutter will cut the flimsy plastic very well. Other than that all you will need is a philips and flat head screw driver and a 10mm socket, and maybe a couple hours.
Knight,
I've helped with several installs now, and invariably, the hole saw never works because there always seems to be some hole position adjustement needed. It sounds good, and seems like if you put the pieces together you could mark the position...so far, no such luck, things just move too much...what the hell, maybe it's worth another shot.
i needed two tie wraps with mine to secure the hoses on the thingamajig (excuse my techinal incompetance) and make sure you dont break the little plastic connectors that hold the shroud on the bottom. as for the hole you have to cut, good luck getting that thing perfect. hopefully aem sent you the right hoses.
AustinS2k2003
Dec 14, 2003 02:09 PM
TampaS2k
Feb 10, 2002 05:45 PM
