Tappy Engine - trial and error tried plese help!
Old Aug 2, 2014 | 06:50 AM
Judgee's Avatar
Default Tappy Engine - trial and error tried plese help!
Hi all, i have a 99 S2000 with 85000 miles on her. Last few months theres been a noticeable metallic tappy noise coming from the engine when cold that gets faster with the revs but also seems to die a little once the car is warm. I have changed my TCT, had my valve clearances re-checked, oil and filter change and also spark plugs. I had thought after looking around on the forum this would have solved it but to no joy. Can there be any other options? Car also made 225bhp on the rollers and I know its an old car and they will always lose power through the years but I cant help but think that this noise is something major and losing me power?
Any help is much appreciated
Thanks
Old Aug 2, 2014 | 08:55 AM
DillonS2000's Avatar
S2000's have loud valve trains - may just be normal. You've checked the right things TCT and valve clearance
There has been talk of the nr4 injector being noisy aswell so maybe consider cleaning / replacing injectors
Have you a video of the noise?
Old Aug 2, 2014 | 09:21 AM
Judgee's Avatar
Literally have just seen a thread about injectors (typical) I will get a video together.
Old Aug 2, 2014 | 11:53 AM
davidc1's Avatar
The mechanic who changed your TCT, and adjusted the valves...what did he have to say?
Old Aug 4, 2014 | 06:59 PM
postman's Avatar
Use a stethoscope to get a better idea of location of noise.
Old Aug 4, 2014 | 07:02 PM
davidc1's Avatar
agreed. A lost art among today's younger and import mechanics.
Old Aug 5, 2014 | 06:20 AM
vtec9's Avatar
Our injectors are very noisy compared to other cars. You can try some chevron techron, or if you really want, you can have them all cleaned and flow tested professionally.. but it may not help.
Old Aug 14, 2014 | 09:04 AM
Judgee's Avatar
I found a video of what mine sounds like, some people on here are saying belt tensioner pulley? I just have a bad feeling its something like a bottom end knock. Anyone with more know how could have a listen any give me any hope? Thanks
http://youtu.be/FGrPjfhppMQ
Old Aug 14, 2014 | 09:15 AM
bgoetz's Avatar
I am going to say that sounds more like something with the pullies vs rod knock. It doesn't have a hollow enough sound to it. Curious to hear other opinions though.
Old Aug 14, 2014 | 09:20 AM
bgoetz's Avatar
This is what I think of when I think rod knock.
http://youtu.be/EUMsNvG5VWc
