TCT DIY - Replacement or repair
#251
#252
Hey there guys i have a weeping tct its only roughly 8 months old but i think the previous owner may have nipped one of the o rings so all i need to do is replace the o rings parts 16 and 15 in the diagram any one know where i could source just these parts please.
#253
Source is the same place the diagram came from. The link:
https://www.hondapartsnow.com/parts-...cam-chain.html
Any Honda dealer can get the parts which may save you a ton of postage.
-- Chuck
-- Chuck
#255
-- Chuck
-- Chuck
#256
The link shows the part numbers.
(Emphasis added.)
Even in the UK.
-- Chuck
Even in the UK.
-- Chuck
#257
Hey guys. I'm having difficulty getting the maintenance hole bolt washer size. It is not mentioned anywhere in the repair manual or the forums. Do I have to replace it or can it be reused along with the hex bolt?
Any help would be much appreciated.
#258
https://www.hondapartsnow.com/genuin...2-pe0-300.html
A generic 14 mm washer should fit. If not, reusing this washer (Flip it over) should work well in this case.
Drakbar (02-19-2023)
#259
Thank you so much. Really appreciate your input. Saved me the hassle of opening and checking.
