TCT replacement
Old Jan 30, 2010 | 05:47 PM
skool u's Avatar
Default TCT replacement
I'm about to reinstall my TCTand have just retracted the plunger and have managed to screw it back in and have the pin secure it into location. I'm taking a look at the top of the plunger and notice that the top of the plunger shaft there are two notches on either side. Do I need to have this oriented a certain way when I pull that pin out through the service hole onn the side of the block?
Old Jan 30, 2010 | 08:14 PM
JDMQuip's Avatar
Should look like this l_ not like _l
Old Jan 31, 2010 | 06:41 AM
skool u's Avatar
Are you talking about the pin I need to remove? When I pull the pin through the service hole, the plunger will pop out and at the tip of that plunger there are two notches or groves and this is what I am referring to. They are on opposite ends of the tip of that plunger.
Old Jan 31, 2010 | 07:36 AM
SpitfireS's Avatar
You can't control the orientation of the plunger when it pops out.
IMO those flat spots on the plunger are used when the tensioner is assembled in the factory, to either keep the plunger from turning or turn it during assembly.
IOW, it doesn't matter.
Old Jan 31, 2010 | 09:34 AM
skool u's Avatar
thanks for that mate. Yeah, when I was looking at it, I was really worried about trying to get it aligned properly!
pmba
Aug 12, 2013 12:27 PM
dominion
Aug 29, 2008 02:36 AM
troll
Jan 22, 2008 04:59 PM
JAPCAB
16
Sep 10, 2007 05:13 AM
agapes2000
Aug 3, 2005 07:07 AM
