Test Pipe
Old Nov 3, 2008 | 01:16 PM
LuDawg's Avatar
Default Test Pipe
Ok, so I'm a little annoyed with my test pipe (Invidia 60MM) right now. It rattles when I'm in low RPM..like 2Kish. When I first installed the TP a couple weeks ago it was fine. Then a few days later I started hearing the rattle. When I first put the TP in I torqued the bolts all the way down on those 2 spring bolts (Sorry, dont know the technical name for them). The rattling got so bad I needed to do something about it so I loosened the spring bolts out about half way. It got a little better but the rattle is still there. Does anyone else have this problem? Do I have to live with it if I keep the TP in? Any suggestions on what I can do? I am assuming the TP is hitting the heat shield that's above it...
Thank you!
Lu-Dawg
Old Nov 3, 2008 | 03:19 PM
05APdeuce's Avatar
check to see if the 02 sensor is tight mine has the same rattle and it was the 02sensor
Old Nov 3, 2008 | 03:30 PM
LuDawg's Avatar
I'll do that for sure. I ran a search and people also suggested taking out TP and re-installing making sure it does not hit the heat shield. I thought it only fit one way but I'm to a point where I'll try anything. This seems to be a comon problem with test pipes. Thanks for the tip
Lu-Dawg
Old Nov 3, 2008 | 03:39 PM
driftintherain's Avatar
yea i had same problem and it was loose 02 sensor
Old Nov 3, 2008 | 06:39 PM
tudernos's Avatar
Just make sure the testpipe or the o2 sensor is not hitting anything. Make sure everything is tight and nothing is interfering with it. That's all I can suggest.
Old Nov 4, 2008 | 06:52 AM
NA20's Avatar
I had the same problem... Make sure the tabs that hold on the heat shield did not break off... It happened on mine so I had a shop weld them back on....
Elvi s2k
Mar 21, 2011 05:43 AM
tmkpres
Dec 31, 2006 01:41 PM
crazysupratt
Nov 9, 2006 08:10 AM
JSWhaler
Apr 6, 2006 05:35 AM
J Roman
Nov 18, 2005 06:45 PM
