Test Pipe - Running rich ?
Old Sep 16, 2010 | 03:09 AM
ifly1956's Avatar
Default Test Pipe - Running rich ?
OK, at 100,000 miles I got a CEL saying my cat was not at 100%. Instead of putting on a new cat, I went with a test pipe and non-fouler for the o2 sensor on the cat. ( I have a 2001)
I ran to Fla this past weekend and stayed right at 70 mph the entire 650 miles each way. After I got back to SC (1500 miles later) I noticed a lot of soot on the outside of my chrome tips. It wiped right off with mineral spirits.
My question - will removing the cat cause this engine to run richer ? Hitting Vtec a few times I saw a puff of black smoke, which usually means running rich. At 70 mph, and the top down, I averaged 32 mpg per tank. Normal, low ?
Old Sep 16, 2010 | 05:28 AM
w00t692's Avatar
Removing the cat you get more particulates and engine oil etc coming out the exhaust...
Think about it man...
And i believe the 2001's already run kinda rich compared to the later years?
Old Sep 16, 2010 | 05:32 AM
S2k_MoZo's Avatar
00-01 runs very rich and 02-03 have a diff tune to run leaner and have more tq to their tune low end. It's normal for you to see tips real black because your cat filters most of it out and if you remove cat there is nothing stopping all the crap from coming out. Sooner or later you'll see it on your bumper too.
If you want to roll with at tp, I would suggest that you should buy an 02-03 ECU from a junkyard. It's not going to fix it totally, but there will be a significant difference.
Old Sep 16, 2010 | 07:11 AM
ifly1956's Avatar
Thanks - I'll think I'll try the ECU swap first.
Old Sep 16, 2010 | 07:21 AM
w00t692's Avatar
I've been thinking about geting an 02-03 ecu for a little while, what can they be had for from a junkyard?
Old Sep 16, 2010 | 07:27 AM
TougeS2k's Avatar
32mpg is fine. I wouldnt waste the time doing the ecu swap. Are you really worried about going from 32 to 33 mpg and about <2 tq. Buy a GReddy single instead
Old Sep 16, 2010 | 09:08 AM
w00t692's Avatar
I have an HKS single.
I think i'll just get a VAFC and call it a day.
Old Sep 16, 2010 | 09:33 AM
deibit's Avatar
[QUOTE=ifly1956,Sep 16 2010, 01:09 PM] My question - will removing the cat cause this engine to run richer ? Hitting Vtec a few times I saw a puff of black smoke, which usually means running rich.
Old Sep 16, 2010 | 09:58 AM
H22toF20's Avatar
Originally Posted by deibit,Sep 16 2010, 09:33 AM
And by the way.. removing the cat ill never add more fuel or reduce the airflow.. (on the contrary)
Stole the words right out of my mouth.
Old Sep 16, 2010 | 10:02 AM
w00t692's Avatar
that's not always true.. in fact in most of the cases it's the other way round.
Running leaner and/or with advanced ignition (on tuned engines), means that the air/fuel mix is more difficult to burn, and therefore can cause incomplete combustion (in the combustion chamber) and could lead to a postcombustion (in the exhaust manifold or in the cat) or even cause smelly black gas balls coming out of the exhaust (specially if u have a test pipe)
In fact running leaner is what causes tuned cars to popoporropo on reductions like harleys (or even to backfire throwing flames in extreme cases).
advanced ignition and leaner fuels cause hotter combustion and can cause preignition. I dunno about more difficult to ignite, more like easier to ignite. I guess that would cause incomplete burn though.
i can attest to very lean sounding like a subaru
2003_Suzuka
Jun 29, 2015 06:30 AM
ifly1956
Mar 8, 2010 04:27 PM
slicko9
Jul 10, 2009 03:17 AM
vader1
Jan 29, 2009 04:26 PM
rotary head
May 25, 2008 10:42 AM
