Test pipe- What to do with the hole for the
If I am not going to use a 02 sensor and just deal with the CEL for a while, what should I do with that hole that was made for it?
If I just leave it open, won't it leak the air out? Is there something stock that will go there?
I don't want to , but I guess I will use the 02 sensor technique found here.
https://www.s2ki.com/forums/index.php?showt...59&hl=simulator
Thanks for any help
Thanks for any help
Originally Posted by jakub2000,May 4 2005, 08:10 AM
forget the O2 simulator...do the mechanic simulator trick, it will run you just a few $
you buy those spacers and lengthen the gap between the bung and the 02 sensor. its trips the airflow and reads normal. only problem is i forget what you need to buy, there was a thread on here about it, just i can't find it.
anyone know what im talking about...
Originally Posted by Guedo512,May 4 2005, 06:06 AM
theirs another trick also.
BTW, you can also do what the "little Dutch boy did".
