Are these things normal?
Old Sep 2, 2005 | 07:42 AM
magikcow's Avatar
Default Are these things normal?
1. When i start the car I hear a very high pitched Whirrring noise from the front of my car. I thought it was my imagination however my friend also heard it. It might be also present when my car is idling with the clutch down.
2. When I put the climate control to all the way to the left without A/C it's still hot as all crap. I thought it was supposed to take air from the outside and well... since my top is down I know what the outside feels and this air is 20-30 degrees higher... it however is lower than when I crank it to the right.
3. Shifter is very notcy.. however I have read everything about it and I was wondering how much is redline?.. Or is that not a good brand of tranny fuild to use.
Old Sep 2, 2005 | 08:55 AM
dozen5's Avatar
doesn't sound too far off.
1. do you have an aftermarket intake? does it continue to make noise after it's warmed up?
2. 20-30 degrees? that's crazy. if it's actually that much of a difference, go back to the dealer and see if it's under warranty.
3. notchy shifter is normal. change your fluid periodically. as to what brand you want to use will depend on what kind of driving you do. or how well you maintain the car.
look into the oil journals. it's a sticky in the technical thread.
https://www.s2ki.com/forums/index.php?showtopic=195574
Old Sep 2, 2005 | 09:54 AM
magikcow's Avatar
Stock OEM intake. And the engine noise drowns out the squeel when it's moving or gets buried under everything.
Man... I guess i'll bring it to the dealer on a day it's supposed to be rainy or something like that... I guess i'll be accord bound for awhile.
Old Sep 2, 2005 | 11:19 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
$8.95 for redline MT-90 in Marketplace!
Old Sep 2, 2005 | 12:38 PM
r_duff's Avatar
#2: check that the lever (linkage) to the vent actuator motor is connected. Have your freind check under the hood while you move the temp control knob in the car. He he looks on the passenger side (next to the battery), he will see a little knob moving. make sure its hooked up to the lever next to it.
Old Sep 2, 2005 | 12:48 PM
twohoos's Avatar
1) is probably the secondary air injection system (emissions thing).
S2K-DJ
Jul 1, 2011 12:09 PM
TomTomTuning
May 13, 2007 06:31 AM
TAKIS2K
Feb 20, 2007 06:24 PM
cytokin
Apr 12, 2005 04:05 AM
RadioSilence
Sep 28, 2004 11:16 AM
