Throttle body cleaning
Old Jan 7, 2006 | 05:35 AM
efthimios's Avatar
Default Throttle body cleaning
is it ok to let soak in carb cleaner before cleaning? or do I need to clean it by hand w/ the cleaner only?
Old Jan 7, 2006 | 07:53 AM
Slows2k's Avatar
If you remove the throttle body from the manifold, just spray untill all the residue is gone.
If you leave the throttle body on the manifold, use only enough cleaner to soften the carbon, and a small wire brush to scubb the throttle opening. To much puddled throttle plate cleaner sitting in the manifold can hydrolock an engine . Some care needs to be taken in how much you are spraying inside the manifold.
Old Jan 7, 2006 | 08:45 AM
efthimios's Avatar
thanks for the info...I had it off the car, switching back to a stock TB from my old Spoon one... the cleaner blasted everything off for me...I'm just letting it sit out to fully dry now...thanx Slow
BOARDPARADISE
Jul 18, 2017 04:54 AM
biggyrap
Jan 12, 2013 03:01 PM
SWFLS2K
May 9, 2011 10:22 AM
Startrek
Dec 25, 2006 09:27 AM
