Throwing code P0410, P0122 AND P1129
there may be a hose disconnected. I got this code a couple months ago after working on my car. Put it back and and it fixed the issue.
P0122 - TP Sensor Circuit Low Voltage
TP sensor is located in the throttle body and you would need to replace the whole thing.
Part Number: 16400-PCX-A01
MY00-03
or it can be a problem with the ECM too
P1129 - Replace the map sensor
Part Number: 37830-PAA-S00
MY00-05
i don't know what year is your car but I searched this under a 2003 cuz thats what I have. If you do replace the throttle body it includes a map sensor so that should fix both codes at the same time
