throwing a p1259 at idle?
Thats what I had assumed. It started DIRECTLY after upgrading to the 1.49 firmware. But I was ASSURED that it was not the problem by people here and on the emanage forum.
Alright. Updat. I was out messing with the software/firmware and unzipping different versions. Doing some things that I don't think I should be doing lol.
I was actually able to get the code to trip WITHOUT THE CAR RUNNING. Key on engine off and it would be thrown. I went to a different firmware and my car was running pig rich pegged at 10:1 the code went away but I couldn't tune the car at all??? I kept forgetting to update the main unit and blah blah blah. I am honestly not to worried about not going into vtec right now. I plan to get rid of this darned emanage. I am just curious as to what could be causing it.
22-25 psi oil pressure at idle and 75 psi at 3000rpms. I am ruling out the oil pressure as being the cause. I ran some continuity tests from the switch to spots higher in the harness and all checked out. I couldn't get a direct shot at the actual vtec pressure switch as my piping is in the way. I did remove the solenoid to check to see if it would open and it does. It may be the oil pressure switch or something in the emanage. I may purchase another vtec solenoid to see if that cures this problem and in about a month will be switching to the AEM.
is somehting like this possible with the OBD-II??
http://www.honda-tech.com/zerothread?id=1693528&page=1
Forcedbird
Aug 18, 2016 10:02 PM
turtlepower
Oct 26, 2012 02:16 PM
