Thumping noise from rear as slowing down.
Old Apr 27, 2013 | 03:01 PM
lee sung's Avatar
Default Thumping noise from rear as slowing down.
When I apply the brakes, I hear a thump thump thump noise from the rear.
This is at about 30mph to 0 mph. As the car slows down, the thumping slows down as well.
I have no idea what's the problem but it only happens whenever I hold the brake and if I let go noise is gone but if I hold it again it makes the noise.
Any idea what it is? I just got my differential fluid done 3 days and I am not sure if that has to do with anything.
Old Apr 28, 2013 | 11:15 AM
lee sung's Avatar
Hmm no reply? I setup an appointment with honda tomorrow to find out whats wrong with it. I am guessing it is brake pads that isnt oem. The dealer who sold it probably did not put oem.
Old Apr 28, 2013 | 11:39 AM
pdexta's Avatar
Does it sound like it's coming from one side more than the other? I doubt it would be differential related if it's only when braking. I'd pull the rear tires off and take a good look at the brakes. Are your rotors stock? I've seen drilled rotors crack before and they'll make a thumping sound like you describe.
Old Apr 28, 2013 | 07:28 PM
lee sung's Avatar
Sounds like one side is louder than the other.
And rotors are stock, so it might be warped.
Pads are new but I can't tell if they are OEM or aftermarket.
But I am assuming that is aftermarket because used car dealership put it in.
I will check with dealership tomorrow if they can find anything.
Old Jun 17, 2019 | 03:03 PM
-ChriS2K's Avatar
Sorry to bump this very old thread. OP, was your issue ever resolved? I am hearing a similar noise from the rear under braking. Thanks.
VTECMACHINE
Mar 18, 2016 01:25 PM
student_driver
Jan 10, 2008 05:23 AM
Itr#249-rip
Dec 26, 2006 03:33 PM
The Raptor
Nov 6, 2005 03:35 PM
Anrosphynx
Mar 19, 2004 02:55 PM
