ticking?
Old Jan 31, 2015 | 03:34 PM
es2k87's Avatar
Default ticking?
Hi guys i got a 2002 s2k and i love it...126k miles had her since 2010 but ex wife cracked the head while i was deployed and warped the cams bad. Finally out (disability) and got her running again well now it occasionally stalls...won't go past 7k rpms until fully warmed up and for this annoying ticking/rattling sound under the hood....can't pin point what it is plus keep getting p1457 as a code. ...any ideas
Old Jan 31, 2015 | 03:39 PM
windhund116's Avatar
What happened when your ex-wife cracked the head? What did you do to fix it? New head and cams? Think p1457 is an emission code. Sounds like you may have several issues.
Old Jan 31, 2015 | 03:57 PM
es2k87's Avatar
Just checked it again another code p1399 random misfire im thinking valves are off? Needing to be redone? Explain the ticking sound. ....have video not sure if i can post it
Old Jan 31, 2015 | 04:00 PM
es2k87's Avatar
No clue what she did. I was in kabul afghanistan at the time lol she wrote me a very angry letter that its my fault haha whatever....yes new head and cams plus new cam towers (cam seats) the old ones snapped. Been sitting for a couple of years. But cleaned her out front to back internals etc....new map new crank angle sensor new head cams......bout it
Old Jan 31, 2015 | 05:05 PM
Yeah, sounds like the car needs a good tune-up. Valve adjustment, spark plugs, maybe oil change, air filter. Usual doo-dads. Then, see what happens.
Good luck!
PS: That ex-wife must have been a doozy. Never heard of bent head and camshafts in one of these cars.
Old Jan 31, 2015 | 06:16 PM
nissanfanatic's Avatar
https://www.s2ki.com/s2000/topic/851...age__hl__p1457
I would be inclined to think the ticking is the timing chain tensioner...
Thank god she is your ex. Good for you.
Old Jan 31, 2015 | 07:15 PM
Miasma's Avatar
Not revving past 7k until fully warmed up is perfectly normal. That is the computer cutting fuel so you don't run a cold engine too hard.
Old Jan 31, 2015 | 07:19 PM
T-Smac's Avatar
1. Ticking could be loose valves, also could be Timing chain tensioner. Does it sound like a card in the spokes of a bicycle wheel?
2. p1457 is an Evap leakage code
3. Not revving past 7k is normal. You don't want to run your car hard when it's cold. It's keeping you from damaging your engine.
Old Feb 2, 2015 | 05:44 AM
es2k87's Avatar
No card in spokes but I'll post the video of the sound on YouTube later and link it so yall can listen as far as valves needing to be adjusted that's next on my list of fixes to be done. Lol ya i havent heard much of the heads and cams failing either...no clue what she was doing.
Old Feb 2, 2015 | 07:07 AM
Heavens Wing's Avatar
My ticking was valves loose. Which is weird because these cars tend to make the valves tighter the longer they go.
