ticking noise from diff end of drivesaft.
Old Dec 10, 2007 | 07:24 AM
krnboi4370's Avatar
Default ticking noise from diff end of drivesaft.
I have recently replace the diff with a newer diff with only 20k on it...and a new tranny as well...but the drivesaft is still the same one...i have a ticking noise present when in reverse or starting of in first gear..i have been through 3 diff and know for sure it is not a diff problem...i got under the car and rotated the play in the driveshaft and their is the same knocking noise coming from the drivesaft when i rotate it and when i drive...so could this be a possible failure of the rear drivesaft bushing??? please and info would be helpful...
Old Dec 10, 2007 | 07:32 AM
ft2057's Avatar
I'm not sure if this could be the same problem you are speaking of, but theres another thread here that just started looking for answers to a similar problem.
https://www.s2ki.com/forums/index.ph...&f=22&t=548721
Not much has been said about this topic yet though.
Old Dec 10, 2007 | 01:54 PM
SpitfireS's Avatar
Do you mean the ticking noise is there for a while?
Or just when you change direction?
That sounds like axle nut torque and/or play in the hub & axle.
If the noise is there all the time I would carefully inspect the inner CV's.
(that means opening them up I guess)
polar2k
Jul 15, 2014 08:20 PM
captain_pants
Jul 31, 2013 10:55 AM
pli
Jun 14, 2008 02:59 AM
PeterMM
Feb 2, 2007 12:10 PM
onani
Nov 12, 2005 07:18 PM
