whistle/vibration noise from the rear.....
I got whistle/vibration noise driving on freeway .. not very noticeable if on bumpy road.. probably because of the engine noise? only occur when its at 75km/h -105km/h... the noise is gone once I release gas pedal..
Anyone got this problem also? Could it be the hub and the bearing? Rear Diff.? ( I got my rear diff. fluid changed 2 weeks ago ) Drive shaft? CV joint?
Did some research afterward, found a thread that related to my problem..
https://www.s2ki.com/forums/index.php?showt...0&#entry6524898
So is it my rear diff.?
I had a very similar sounding problem, mine turned out to be the diff, I would definitely get it checked, especially if you just changed your diff fluid. Someone might of forgot to plug it back up right etc.
defective? crack? broken bolt? missing bolt?
Thanks
BlueS2000Boy
01-09-2006 07:55 AM
