Tightening Handbrake
Take the console off like you would if you were trying to change your shifter, and by the storage compartment there is a turnbuckle kind of mechanism and I think it takes a 10mm wrench. you should be able to take it from there. I did this not even a month ago and it worked pretty well as far as I can tell. I mean I don't have to pull the handbrake up near as high as I used to. Just make sure you don't tighten it too much to where it is engaging with only one click of the brake. Cause that would be bad.
JDMpearlwhyteZ
Jul 26, 2013 10:16 AM
