Timing chain guide replacement
Old Dec 5, 2015 | 01:22 PM
Tampa s2000's Avatar
Default Timing chain guide replacement
2000 S2000 need to replace the chain guides is it possible to replace without removing the head.
Old Dec 5, 2015 | 06:00 PM
Slowcrash_101's Avatar
How do you know the guides are bad?
Old Dec 6, 2015 | 03:08 AM
Tensioner guide was damaged during install of head metal tab on top was broken off.
Old Dec 6, 2015 | 06:59 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
You can pull the oil pan then timing cover to do the job, head can stay.
Old Dec 6, 2015 | 12:42 PM
Billman thanks for the advice it's all out! I do have to mention reading the manual it instructs to remove everything, surprised they don't recommend removing the Pistons, go figure flat rate hours.
Is there anything else I should address it has 117k motor looks super clean.
Old Dec 6, 2015 | 04:22 PM
Billman250's Avatar
Top Answer: 1
There was an oil pump update, if you are in that deep it would be a nice upgrade for little work.
Bad1flip
Jan 6, 2018 05:10 AM
Atheist
Aug 17, 2007 10:04 PM
NFRTurboTerror
Feb 6, 2007 05:45 AM
dupak633
Jun 13, 2006 06:19 PM
SlideWayz
May 3, 2005 02:44 PM
