timing seems to be off...
Old Jun 30, 2016 | 12:38 PM
r32gaijin's Avatar
Default timing seems to be off...
hey guys.
I don't own an S2000 and don't know about the specific issues with them.
I've jumped around on a few threads and haven't found this particular issue.
My buddy's S2K just had plenty of engine work done. I've checked timing marks and everything lines up how it should. However once warmed up, it gets a bit sluggish in terms of throttle response. I checked it with a timing light and seems to be off a bit (timing marks both red and white on crank pully are off to the drivers side of the car by about half an inch from the arrow on timing cover.
The car has all new cam and crank sensors, all new timing components.
Any leads or pointers of where to start?
Sorry for the n00b questions. I don't like asking them any more than you like reading them. lol
Old Jun 30, 2016 | 02:46 PM
Slowcrash_101's Avatar
I'd look at the valve adjustment, that can have a big impact on power and drivability. Also I'd take a look at the spark plugs, make sure they're properly tightened to ~22-24 ft/lbs + a tug.
Old Jul 1, 2016 | 04:30 AM
r32gaijin's Avatar
valve adjustment is perfect and plugs are fine.
i guess this issue was present before the block and head was replaced. replaced the ECU, harness, cam sensors... i'm just not sure what would pull almost 15 degrees of timing when the computer says everything is fine. it won't pop up any codes... a real head scratcher on my hands
Old Jul 1, 2016 | 04:55 AM
s2000ellier's Avatar
whats odb2 timing degrees reported at idle?
HS2K007
Mar 27, 2011 08:44 PM
D2 TEX
Mar 17, 2011 02:15 PM
Rasetsu99
Sep 14, 2010 06:45 PM
s2konroids
Jun 2, 2010 10:50 AM
i build motors all day
Dec 1, 2009 08:37 PM
