Tips for Head removal
Old Jan 19, 2007 | 07:06 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Ok...maybe he has crossed the "drive it hard/beat the crap out of it" line
Old Jan 19, 2007 | 07:18 PM
jimi's Avatar
Sounds like straight up abuse. What a waste of money
Old Jan 20, 2007 | 10:39 AM
aero3685's Avatar
OK..
Piston # 2 does not move up/down with the crank. 1 valve is obviously bent, rocker arm for that valve is broken and piston looks to have a few scratches.
Here are some pics. any ideas?
Old Jan 20, 2007 | 11:08 AM
Billman250's Avatar
Top Answer: 1
The #2 connecting rod is broken. The engine is obviously junk.
It broke the rod, the piston came up and hit the open valve, breaking the rocker arm.
Old Jan 20, 2007 | 11:34 AM
BlownAP's Avatar
what do you think would cause a broken connecting rod billman?
abuse/ high revs? lack of maintenance?
Old Jan 20, 2007 | 11:57 AM
Billman250's Avatar
Top Answer: 1
First thing would be low oil.
Second would be a serious mechanical over-rev.
How fast was he going?
Old Jan 20, 2007 | 02:06 PM
aero3685's Avatar
anyone think it'll be a good canidate for a 2.4 liter setup??
Gotta replace rods/pistons/crank anyways.
Old Jan 20, 2007 | 02:34 PM
Billman250's Avatar
Top Answer: 1
I'd have a good look at the lower end of the cylinder walls. There's a chance the rod crashed into the bottom edge, by the oil jet.
Old Jan 20, 2007 | 02:36 PM
Billman250's Avatar
Top Answer: 1
Take a nut or something and glue it to that broken piston with construction adhesive. Then pull it out. It should pull right out with a broken rod.
Old Jan 20, 2007 | 03:08 PM
aero3685's Avatar
brilliant... gonna go jbweld one to the top of it right now.
edit: No luck.. jbweld just popped right off, and I dont have any other glue stuff.
