Tire question
Old Feb 11, 2010 | 03:39 PM
cpl_allen's Avatar
Default Tire question
So reading around the forums, something suddenly dawned on me. I think my tire size is wrong.
In the front im running 225/45r17
In the rear im running 245/40r17
Dizerra starspecs on a 17x7 wheel.
Why would i run 45 in the front and 40 in the rear? These are the numbers tirerack gave me
Old Feb 11, 2010 | 04:13 PM
ZDan's Avatar
45 and 40 are the aspect ratio, the tire's sidewall height represented as a percentage of section width. 225/45 has a sidewall height of 0.45*225 = 101.25mm. 245/40 sidewall height = 245*.40 = 98mm. So your front tires are about 6.5mm bigger in diameter than the rears. Not a big deal as far as function goes, but IMO 225/45-17 fronts with 245/40-17 rears doesn't look quite right (fronts look noticeably bigger than rears).
Your sizes aren't necessarily "wrong", but for me the preferred size options on AP2 wheels would be:
215/45-17 front, 245/40-17 rear (stock AP2 sizes)
215/45-17 front, 255/40-17 rear (stock CR sizes)
225/45-17 front, 255/40-17 rear
Old Feb 11, 2010 | 04:31 PM
cpl_allen's Avatar
hmm. I see. So a tire with 215/45 will have a smaller diamater than a tire with 225/45, as well as a smaller footprint.
I'm also getting some slight rubbing and looking at other pictures of s2k's, i notice that their tires arent as flush with the fender as mine are. Some of the slammed s2k's look like the tires ride within the inner lip of the fender.
Fair enough. Good info. When I get some decent wheels, I'll be sure to go with a 215'ish front.
akuzus2k
Jan 12, 2018 10:02 AM
CBR_S2000
Nov 2, 2016 05:10 AM
JDMpearlwhyteZ
May 8, 2012 02:19 PM
JumpDriver
Apr 18, 2009 07:41 AM
Ape_X
Mar 5, 2008 10:47 PM
