Torque spec on updated 19mm front subframe bolts
Old Oct 22, 2017 | 09:36 PM
Soviet's Avatar
Default Torque spec on updated 19mm front subframe bolts
Hi all, was checking the torque of the front subframe bolts on the CR and noticed that it had the updated 19mm bolts (instead of 17mm bolts).
Was curious if the torque spec was still 43 ft-lbs or not... I have a feeling the rest of the bolts may be the same as the original 17mm bolts except for the head. They didn't seem to be torqued to 85 ft-lbs like the rest of the 19mm bolts.
Majestic Honda shows BOLT, FLANGE (12X202) which I'm guessing means it should have the same 43 ft-lb torque spec.
Thanks in advance..
Old Oct 23, 2017 | 04:34 AM
Stratocaster's Avatar
the bolts are still the same, only the heads were changed to make them uniformed. So the torque spec would be the same.
Old Oct 23, 2017 | 05:28 AM
s2000ellier's Avatar
19mm bolts? thats 4 unga-dungas
Old Oct 23, 2017 | 06:14 AM
windhund116's Avatar
These charts may help you.
"Nominal diameter" is the diameter of the bolt (threaded portion), not the hex head.
Bolt (thread diameter) versus bolt head (hex head) sizes.
Old Oct 23, 2017 | 07:28 AM
B serious's Avatar
I found it strange that Honda was using a combination of M12 and M14 bolts for this application.
Its going to be more confusing now, if they are using 19mm hex heads for both thread sizes.
Old Oct 23, 2017 | 08:07 AM
Soviet's Avatar
That clears things up, thanks.
Sorry dad
So it looks like they switched from JIS to DIN?
Yep. Hopefully this thread clears things up for anyone in the future.
chubbys2k
Feb 22, 2016 07:11 PM
kop-O-nen
Mar 21, 2013 05:08 AM
xowner
Mar 10, 2011 03:36 PM
