torquing spark plugs
Old Oct 19, 2008 | 05:13 PM
scottieboy561's Avatar
Default torquing spark plugs
i was about to do my spark plugs when a friend told me that i have to torque them to a certin setting or w/e he said if i dont i could blow the motor is he right?
Old Oct 19, 2008 | 05:14 PM
vincewchan's Avatar
I believe the manual says 18lbs of torque for the spark plug
Old Oct 19, 2008 | 05:35 PM
TelosHedge's Avatar
16 or 18 i forget. either should be sufficient.
you dont want them too loose because they can break apart and get into the combustion chamber. if that happens and you're lucky the broken piece will run through the motor and hurt nothing and end up in the exhaust but that doesn't always happen...
Old Oct 20, 2008 | 06:30 AM
SgtB's Avatar
...too tight and you'll strip the threads which is quite an expensive mistake.
Old Oct 20, 2008 | 09:34 AM
cdelena's Avatar
The original spec (and less than optimal washers) led to many plugs backing out and engine failures. A recall introduced plugs with different washers and a higher torque spec. I have used 18 - 20 lb/ft with good results.
rob-2
Feb 9, 2010 12:41 PM
J_STATUS
May 5, 2008 04:55 AM
SPLNDID
Sep 22, 2007 11:49 PM
Unspooled
May 31, 2007 09:57 PM
buzilanga
Aug 7, 2004 07:38 PM
