tranny fluid
Originally Posted by emrillive,Sep 26 2004, 05:21 PM
is trhis fluid safe for my04? cause the my04 has cf syncros
Honda uses MTF in all its S2000 trannies - the 2004 does not need anything special. Do a Search on the analysis and comments I made on GMSFM in my 2004. Skinny: it worked great.
Oh, it is LE-607, not 601 by the way.
I used the black bottle as purchased from my local Chevy dealer.
This stuff makes it so easy to shift you have to be careful and more precise, no joke.
I tried Redline MTL and MT-90 prior to the GMSMFM. MT-90 worked well after 30 minutes of driving, but not nearly as good as the the GM...
Originally Posted by Squeezer,Sep 27 2004, 06:42 AM
I won't put GM anything in any of my vehicles. my tranny has honda MTF and the diff has mobil 1 75w-90
Seriously GM obviously doesn't manufacture the fliud it just happens to be designed for a GM tranny but happens to work rather well for other trannys. There are a ton of people using it in a variety of trannys
Conformist in the transmission but non-conformist in the diff?? Your reasoning seems a little flawed.
Originally Posted by oakfloor,Sep 25 2004, 10:08 AM
red line mt-90 best gear lube I have used as of now. will try gm next oil change. drive safe
Redline MT-90 is great. I changed my tranny at 30k and its runny
smoother than ever.
Originally Posted by CrazyPhuD,Sep 27 2004, 01:01 PM
So I guess we don't have to worry about you doing an LS6 swap then
