tranny fluid.
Old Feb 26, 2005 | 01:49 PM
emrillive's Avatar
Default tranny fluid.
i know your supposed to raise the car up on its driver side and then fill her up with about 2 quarts, thenlet the excess fall out while on level ground.
But i was just curious cause i had a situation where my tubing fell out as i was pumping and i spilled a good amount. And i dont know if i didnt have the car raised high enough but there was no way near 2 quarts that went in the tranny.
i believe that at the most i had 1.7 quarts in the tranny all said and done.
in the owners man. it doesnt say exactly how much goes in , so i wondered does anyone know?
Old Feb 26, 2005 | 02:09 PM
Slows2k's Avatar
The service manual lists 1.56qts for a fluid change.
Old Feb 26, 2005 | 05:56 PM
Utah S2K's Avatar
Capacity is 1.56 US qts (1.30 Imp qrts.) as Slow said. It is common practice to "jack" the car to allow more fluid in (~1.65-1.75 qts). In theory more fluid allows more thermal mass to dissipate heat.
Utah
Ref: 2001 Service Manual 3-4
Old Mar 6, 2005 | 05:26 PM
VTECorona's Avatar
Buy 3 qts to be safe. I went to the dealership to buy 2 but the guy at the parts dept recommended 3 just to be safe so I went with it. Glad I did because it is hard to get every drop out of the bottles (unless you have a long tube\pump), plus if you spill some you don't want to have to run out to get more.
ian05s2k
Apr 7, 2008 02:32 PM
Scooterboy
Mar 11, 2008 07:39 AM
jinn21
Mar 27, 2006 09:33 AM
allenheathdj
Apr 29, 2004 06:44 PM
