tranny problem
Old Feb 14, 2007 | 11:43 AM
navysooner's Avatar
Default tranny problem
When I am pressing on the clutch I can't get my stick into gear or its really hard to get it in gear. When the car warms up it seams to be better but I have alot of play in the clutch pedal. Anyone know what this could be?
Old Feb 14, 2007 | 02:17 PM
snakeeater's Avatar
Clutch isn't disengaging completely. Bleed the hydraulic line between the clutch master cylinder and its slave cylinder.
Old Feb 14, 2007 | 07:35 PM
donkeykong's Avatar
I just went through the exact same thing. My problem ended up being a leak in the clutch cylinder. I bet if you look in your engine bay the clutch fluid is low. Pouring more in would be the simple fix, but it will obviously continue leaking. I ended up replacing the clutch cylinder and master cylinder since according to the technician "when one goes the other is soon to follow." Bottom line is it ended up costing $278.
It works great now.
Old Feb 15, 2007 | 10:36 AM
navysooner's Avatar
thank you guys. I took the car into honda and they said they didn't see any leaks and added fluids and it is working fine now.
Old Feb 15, 2007 | 07:06 PM
donkeykong's Avatar
That's odd. I wonder where the fluid went?
Old Feb 15, 2007 | 07:36 PM
HiRpmVTEC's Avatar
samething happened to me like 2 months ago, fluid was very low, i added, still full to this day
Old Feb 16, 2007 | 10:24 AM
navysooner's Avatar
Does anyone have a diagram of where the master and slave cylinder are? It doesn't seem to be using the fluid. I am going to bleed the line to see if something is clogged up.
John'
Feb 20, 2013 05:12 AM
s2k harry
Sep 30, 2010 07:11 AM
NtrllyAsprtd04
Oct 9, 2009 06:00 AM
epaplia
Oct 20, 2008 10:16 AM
TrackStar
Jun 22, 2007 01:23 PM
