TRANSMISSION
Old Dec 18, 2004 | 07:20 AM
S2oooNvegas's Avatar
Default TRANSMISSION
has anyone on this forum had an s2k trans apart? what id like to know is, are there any tricks, lil things i may need to know etc. i plan on getting a helms manual and see what it has to say. but if anyone in here has done a few and has some info that will help, id like to hear it. ill pick up any of the special tools i may need to seperate it, or jigs etc. it seems to me, the part that fails most on our gearboxes, is the sliders. couple missed gears and your done. so im gona start gathering parts and when it wont shift, apart it comes. laters and thanks for any info ahead, dave.
Old Dec 18, 2004 | 08:42 AM
noone's Avatar
Wow, that is the best bottom end I've ever seen. Good Job!!!
Old Dec 18, 2004 | 11:43 AM
apex2k's Avatar
Sorry . . . . umm, did you say something?
Old Dec 18, 2004 | 12:14 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I'll be taking apart an 03 in the next week or two.....we'll compare notes
Old Dec 18, 2004 | 10:17 PM
sounds good billman. thanks ahead for any insight. dave
Old Dec 19, 2004 | 06:31 PM
chris_barry's Avatar
Apart from the usual spanners,sockets and bearing splitters, the only specialist tool seems to be used to hold the spigot while you undo a huge nut on the output sprocket that drives the output shaft in the shifter housing.
I gutted an old clutch plate to get the splined section, then welded on some scrap steel to make a ghetto version of whats shown in the workshop manual.
More like a front wheel drive gearbox inside.
Chris.
Old Dec 20, 2004 | 03:47 AM
S2000RAT's Avatar
Old Dec 20, 2004 | 07:26 AM
Squeezer's Avatar
wow that pic is not work safe i believe. anyway yes you need some special tools to work on the transmission
Old Dec 20, 2004 | 09:40 AM
rogerio1234's Avatar
Talking
I just could not resist, sorry.
http://www.mustangmods.com/data/497/nutcracker_#.jpg (just change # for a number)
Old Dec 20, 2004 | 11:04 AM
Asura's Avatar
You will need a very large allen that you can also apply a significant amount of leverage to.
chris_barry
May 25, 2009 04:41 AM
no_s2k
Mar 30, 2007 08:46 AM
DaveOnLI
Aug 28, 2006 12:55 PM
LubedKoala
Jul 12, 2005 07:56 PM
designfreak
South Florida
Aug 23, 2004 03:20 PM
