Transmission Burn?
Old Nov 21, 2001 | 09:50 PM
MarvinB.'s Avatar
Default Transmission Burn?
Accelerating in 3rd gear from 3000 rpm to 7000 rpm I noticed a slight odor which I associated with a transmission. Straight road, flat, I was already in third gear so its not a shifting into the gear issue. Is this normal for anyone else? Marvin
Old Nov 21, 2001 | 11:00 PM
RT's Avatar
RT
What do you mean by an odor which you associate with a transmission? 90W smell? or ................?
Why you only taking it to 7 grand
Old Nov 22, 2001 | 05:25 AM
s2ktaxi's Avatar
Maybe the smell was caused upon the initial launch and you only smelt it when you go the the higher gears?
Old Nov 22, 2001 | 12:38 PM
cdelena's Avatar
I would guess it is your clutch slipping.
Old Nov 22, 2001 | 12:53 PM
MyBad's Avatar
It's happening to me too! First noticed it 500 miles ago during a launch, but recently I've experienced the same smell under normal conditions.
I've also noticed that while in slow-moving (crawling) traffic, I get a sorta jerky response while easing out the clutch. Plenty of revs though. It seems to be getting worse.
With only 3,200 miles, I can't believe this is happening!!!
Old Nov 24, 2001 | 04:09 PM
rpmsyd's Avatar
MarvinB, same here was on 3rd already, some oil burn smell, they did not last long as it quickly went away, was doing b/w 6000 rpm and 8000 rpm. hope its just some residue oil splashed in the engine and somehow got burn when the engine hots up....
Vindowviper
Dec 8, 2014 02:23 AM
SARmedic
Apr 4, 2011 10:50 AM
iDomN8U
Jul 26, 2008 10:08 AM
Beave0101
Sep 24, 2004 03:25 PM
