Transmission fluid - Motul
Old 02-03-2016, 07:50 AM
klemen123's Avatar
Default Transmission fluid - Motul
Hi,
Is it ok to use Motul Gear 300 75w90 GL-4/5 in ap1 transmission? I read a lot about tranny fluid for ap1 on this forum and i found out that the oil needs to be API GL-4 and this one is.
Has anyone tried this oil in transmission?
https://www.motul.com/system/product...pdf?1303320907
https://www.motul.com/us/en-US/produ...iscosity%5D=58
https://www.euroton.si/avtodeli/motu...-p-219592.aspx
sory for my english
Thank you for your answers
Old 02-03-2016, 11:25 AM
Slowcrash_101's Avatar
That fluid is a bit too viscous for the transmission. Why not Oem fluid, it's relatively cheap.
Old 02-04-2016, 04:03 AM
klemen123's Avatar
oem fluid is more expensive here, and in hot summer sometimes it feels to thin. I would like to try it if it will make shifts smoother , sometimes (very rarely) i do get a little grind from first to second gear .
I just want to know is it safe to use in ap1 tranny because it says both APIGL-4 and 5. people at Motul are recomending it now for ap1 also cause they have changed the formula to suit GL-4 trannys also.
Old 02-04-2016, 08:28 AM
flanders's Avatar
Shouldn't be any problems using that. It's not a big difference in viscosity, I think the oem fluid is 75W-80.
If you are tracking your car it might even be better.
Old 02-04-2016, 08:36 AM
klemen123's Avatar
yes im planing to track my S this year once a month ,
i found this technical data form motul´s site and it says: Suitable for any type of seal and yellow material used in gearboxes design.
Anti-corrosion, Anti-foam...... soo yaaaay i just ordered 2 litres of Motul gear 300 for tranny and Motul Gear 300LS for diff.... cant wait
Thanks for your help
https://www.motul.com/system/product...pdf?1290086772
Old 02-04-2016, 08:48 AM
klemen123's Avatar
https://www.s2ki.com/s2000/topic/199...ssiebrit-help/
Old 02-05-2016, 10:54 PM
klemen123's Avatar
shipment has arrived now just waitng for 300ls
motul by Klemen Jeram, on Flickr
Old 02-20-2016, 09:33 AM
klemen123's Avatar
changed all fluids....
Engine: Motul 300v 5w-40
Gearbox: Motul Gear 300 75w90 API GL-4/5
Diff: Motul Gear 300 LS 75w90 GL-5
New vtec solenoid top gasket thanks to Balladesports .
I am amazed with Gear300 in tranny.......smooth shifts (probably needs a few minutes of driving to warm up, but its smooth even when cold), 2nd gear grind dissapeared, 3rd gear notchyness dissapeared, less tranny noise......... il se how it does in summer when its very hot . Honda MTF was terrible in hot summer.
Old 03-02-2016, 11:59 PM
lheonrd's Avatar
I replaced the honda fluid with Amsoil trans fluid. There's really an improvement in shifting now.
Old 03-03-2016, 03:29 AM
Chuck S's Avatar
Received 1,138 Likes on 1,001 Posts
If Honda MTF is not available, you
may use an SAE 10W-30 or 10W-40
viscosity motor oil with the API
Certification seal that says ‘‘FOR
GASOLINE ENGINES’’ as a
temporary replacement. However,
motor oil does not contain the proper
additives, and continued use can
cause stiffer shifting. Replace as
soon as it is convenient
-- Chuck
Quick Reply: Transmission fluid - Motul
