Transmission fluid without Jack stands.
Old Sep 15, 2010 | 03:14 PM
Calamari's Avatar
Originally Posted by lols2000,Sep 15 2010, 01:59 PM
No, the car has to be level because the only way you'll know the tranny is properly filled is when it comes pouring out of the fill hole.
I actually put a big leveler (the kind with a bubble) against one of the frame rails to make sure the car is level.
True Story.
I would say get 4 jackstands and have it leveled before trying to refill. Besides, you really need that space to get the leverage to pull the bolts off, as well as the drain pan.
Old Sep 15, 2010 | 05:33 PM
INTJ's Avatar
It doe NOT need to be level, but it certainly does need to be high enough to fit under. I use ramps. The level part has been discussed ad nauseum, use the search.
Old Sep 15, 2010 | 07:08 PM
dammitjim's Avatar
Dig a big hole in your front yard and drive over it. Climb in the hole and you're set.
Old Sep 15, 2010 | 07:12 PM
hypforlife32's Avatar
i have changed my engine oil with my car on the ground, i didnt jack it up or anything...and i did it at 1am in a community parking lot. thank god for led flashlights.
i dont know about trans fluid though...
Old Sep 15, 2010 | 07:13 PM
dammitjim's Avatar
I ate lunch today while sitting in a chair that was on the ground. Sandwich FTW.
01SSM
Jul 20, 2023 05:21 PM
Jazzman
Sep 8, 2012 06:06 PM
hicabi
Jul 2, 2008 03:14 PM
Jasonoff
Apr 4, 2006 02:14 PM
clawhammer
Apr 3, 2006 05:27 PM
