transmission mount install?
Old May 24, 2012 | 10:46 PM
ls1->s2k's Avatar
Default transmission mount install?
information regarding a factory transmission mount swap seems to be hard to come by; what needs to be done in order to get the old ones out and the new ones in?
thanks
Old May 24, 2012 | 10:56 PM
meccjoo's Avatar
I would like to know this as well.
Old May 25, 2012 | 04:25 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Just go under the car and look at it. It couldnt be simpler.
The job is self explanitory, like changing a wheel.
Old May 25, 2012 | 09:17 AM
ls1->s2k's Avatar
oh alright, i was expecting it to be more complicated, as with most other things involving the transmission on these cars.
Old May 25, 2012 | 09:53 PM
meccjoo's Avatar
it is rather simple however i was more interested in the torque values for the mount bolts. these are nowhere in the shop manual.
Old May 26, 2012 | 04:19 AM
AP1Theory's Avatar
It's a simple unbolt and bolt install. There's only one mount; three bolts from the mount to the chassis and a few from the mount to the tranny. If installing using a jack and jackstands, you'll need a jack to hold up the transmission while the mount is off.
Old May 26, 2012 | 04:20 AM
AP1Theory's Avatar
The torque specs to the transmission mounts are 28ft lbs.
Old Jan 3, 2013 | 10:00 AM
spaded.racer's Avatar
I was planning on doing my transmission mounts the same time I do my motor mounts. While I have the engine lifted with a jack to do the motor mounts will I also be able to do the transmission mounts since everything is connected?
I don't see why not.
Old Jan 3, 2013 | 11:45 AM
CoolGuy094's Avatar
No, I would recommend doing them independently. The transmission mounts are near the rear of the transmission, and the engine mounts are right at the middle of the engine. They are fairly far apart from each other, and it would be difficult to place a jack in the center of mass to lift the motor and transmission straight up. You will place the jack under the rear of the transmission while replacing the trans mounts, and under the front of the engine while replacing the engine mounts.
I remember finding a thread on how-to replace motor and transmission mounts on this site. It may not have had pictures, but a good detailed description. It exists if you look hard enough for it.
surfaccing
Oct 26, 2018 03:04 PM
jean-roch
Jan 11, 2014 01:15 PM
rworne
Jul 26, 2006 08:02 AM
vjarnot
Jul 13, 2004 05:00 PM
