Transmission Noise with video (Tried Everything)
Old 01-17-2019, 10:37 AM
LagunaPearlAP2's Avatar
That wear does look pretty nasty tho... probably a good thing you changed those out anyway.
Old 01-19-2019, 04:04 AM
Slowcrash_101's Avatar
May be bearings on the prop shaft.
Old 01-19-2019, 08:15 AM
Muiris's Avatar
Well guys,
I tried some tests today and recorded the video below. 1080p with high volume helps.
The first part of the video is the high pitched noise. I couldn't replicate this on the axle stands. At around the 10 sec mark you should hear the "SHEEEE" noise.
I could replicate the rumble noise on the axle stands. The rest of the video shoes this. Check out 1.49 sec mark.
At this stage i'm leaning towards the differential. I think maybe the low speed rumble and high speed "SHEEE" noise could be the same bearing(s), just at a different frequency.
https://www.youtube.com/watch?v=uED-...ature=youtu.be
Also, i've replaced the diff oil and repacked the cv's with grease.
Old 01-20-2019, 08:42 PM
Great video, it really shows the noise well. Can you tell which side of the diff the noise is coming from? I guess if you’ve gotta pull the diff apart to replace either of them it doesn’t really make a huge difference.
Muiris (01-21-2019)
Old 01-21-2019, 09:17 AM
Muiris's Avatar
Thanks, it seems to be where the propshaft joins to the diff. It sounds almost like the rumble is from the pinion/crown gear.
Any other ideas/anyone seen this before?
@S2KPUDDYDAD
Old 07-24-2019, 11:25 PM
Dethred's Avatar
Did you ever resolve this, OP? I have a similar grinding/rattle below 2500rpm under load, but no whining noise after that. Car only has 4150 miles on it, so hopefully it's nothing major. Thanks for any info you have!
Jimbogiant
07-15-2015 07:17 PM
Cheese13
05-01-2015 02:45 PM
Shaney
01-17-2015 06:32 AM
trainhead
01-16-2010 08:02 AM
Quick Reply: Transmission Noise with video (Tried Everything)
