Transmission Problem
Old Feb 25, 2007 | 06:29 AM
powerofdream's Avatar
Default Transmission Problem
Hey guys, i have a problem with my gearbox
its when i back off the accelerator, i can hear a loud buzz/grinding etc noise coming from the gearbox. i've been told its a bearing, not sure which 1 though.
if somebody has had similar problems (i've read abt ppl having problems in neutral etc) pls let me know how u've solved it.
cheers!
p.s i drive a 99 model
Old Feb 25, 2007 | 08:16 AM
gomarlins3's Avatar
Could it be the dreaded clutch buzz?
Old Feb 25, 2007 | 01:01 PM
SpitfireS's Avatar
A Buzzz... buzzzzz while decellerating in 3rd or 4th gear @ 3500 - 3000 rpm?
gomarlins3 Posted on Feb 25 2007, 06:16 PM
The suspense is killing me!!!
powerofdream Posted on Feb 25 2007, 04:29 PM
And still on the original clutch?
Impressive.
Old Feb 25, 2007 | 01:35 PM
Utah S2K's Avatar
Take a look at your VIN. Is the number before the "T" 1999 or 2000? Technical service bulletin (TSB) 00-054 covers a deceleration buzz as you describe (and other board members are noting).It is very common on the 2000 and early 2001's. If you have a buzz when decelerating from 4K to 3K you may have this issue. Honda did not provide a specific VIN range for this issue. Do a search on TSB 00-054 and you can probably get a copy here somewhere.
Utah
Old Feb 25, 2007 | 10:27 PM
thanks a lot
Old Feb 25, 2007 | 11:18 PM
IP_Andrey]RUS['s Avatar
I just got my s2000. Its my00 with 12878 miles on it. Have same issue. Will dealer cover me even I dont have waranty on my car since I baught it from third owner and they never extended waranty??? Thanks
-Andrey
Old Feb 26, 2007 | 05:12 AM
i have find de HONDA Service Bulletin 00-054 Buzzing From the Engine or Transmission While Decelerating
(Supersedes 00-054, dated March 20, 2001)
http://downloads.hondatech.info/Auto/Servi...000/A00-054.pdf
it says: de problem is clutch disc,
CORRECTIVE ACTION
Replace the clutch disc with the improved clutch disc
PARTS INFORMATION
Clutch Disc: P/N 22200-PCX-055, H/C 6855126
III have a Q : if i replace a aftermarket like a normal heavy duty one (exedy) , is it can be fixed???
does anyone have experience??which brand ,which modle???.....
thanXXXXX....
ps: 1999 s2k (AU)
-leon
Old Feb 26, 2007 | 12:02 PM
Ok so I got back from a Honda Dealer, i was getting new pcv valve for my prelude and I asked them about TSB. They told me my car is not covered for the reason off this is only for cars that have warranty on them. Well that blows. I will stop by another dealer just to make sure!
Old Feb 26, 2007 | 12:20 PM
RedY2KS2k's Avatar
Originally Posted by IP_Andrey
RUS[,Feb 26 2007, 04:02 PM] Ok so I got back from a Honda Dealer, i was getting new pcv valve for my prelude and I asked them about TSB. They told me my car is not covered for the reason off this is only for cars that have warranty on them. Well that blows. I will stop by another dealer just to make sure!
Your '00 is 6 years old!
Old Feb 26, 2007 | 12:35 PM
7 to be exact, and still have 12990 miles on it
3vilmonkey!
Aug 18, 2008 06:58 PM
Chris_l
Feb 25, 2007 01:07 PM
jonomo
Jul 31, 2006 12:18 PM
hondax2000
Mar 3, 2006 08:02 PM
hondafirst
Jan 6, 2003 03:44 PM
