Transmission rebuild?
Old Jan 5, 2008 | 03:09 PM
Stealth_SUX_'s Avatar
Default Transmission rebuild?
My car has a bad 1st and 2nd gear, or the syncros are just screwed up. Do you guys know how much it ussually costs to fix that...
I already have the transmission pulled so that work is done..
Should I take it to a dealer have them do it or any other recommendations.
Old Jan 5, 2008 | 05:29 PM
Stratocaster's Avatar
More than it will be to buy a good used trany. The removal/install time is books out at 6.5 hour. The rebuild parts alone will be more than a used tranny. 1/2+Sync are sold as a set and list for over 500. labor will surely bring the job in at over 1k.
Good luck
Old Jan 5, 2008 | 06:54 PM
J'sS2K's Avatar
I say rebuild. It costs a bit more, but it's new. Buying a used tranny is a good option, but there is chance you may need to "rebuild" it again.
Jason
Old Jan 5, 2008 | 11:02 PM
jyeung528's Avatar
if you get new 1/2 gears, you get the new carbon synchros...
Old Jan 6, 2008 | 06:56 AM
rob!'s Avatar
i researched the same thing. ended up going with an ap2 trans. If you want i have an ap1 trans i would let go for very cheap with a high rpm 2nd gear grind. If you dont want to deal with the down time.
Old Jan 6, 2008 | 09:05 AM
I havent decided to buy a used one or rebuild but how do I know what to order if I do rebuild. How do i know which is carbon and which is regular. Also what year does it start where they already have the carbon syncros in them.
Old Jan 6, 2008 | 10:13 AM
The OEM replacement parts were updated for all years. So if you rebuild with new parts, you get that as well. All of the AP2 transmission have them. 04+
Thanks
Jeff
Old Jan 6, 2008 | 05:35 PM
truekakaka's Avatar
after the MY00 TSB for 1-2 gear grind don't all s2k's have the updated stronger synchros?
Old Jan 6, 2008 | 07:13 PM
jyeung528's Avatar
that's different from the carbon synchros...
djortiz6
Apr 21, 2014 06:56 AM
Mushu.MTL.S2K
Jun 11, 2012 06:30 AM
rob!
Jul 28, 2008 08:08 PM
Sir_Sumo
Jul 29, 2006 08:26 AM
bluesaint
Dec 10, 2005 06:34 PM
