transmission upgrade
Old Jan 19, 2006 | 11:28 AM
SC-S2000's Avatar
thats one thing i forgot to say was i had drained the gear oil out the tranny and found no shavings or chunks what so ever so i am hopping to get the trans out this evening and hopefully see the clutch messed up because i will try to get a replacement under warrenty if it is the clutch. since it only has maybe 7,000 miles on it. and for a street disc thats nothin.
Old Jan 19, 2006 | 11:41 AM
xviper's Avatar
You should check out your rear diff as Cdelena suggested. It would be a shame to pull the tranny and find nothing wrong, but rather that it's your diff that's gone.
Not sure who holds the warranty on your 7K mile clutch but with a S/C and since it's a wear item, good luck. Stock cars have been known to blow a clutch in 5K miles.
Old Jan 19, 2006 | 11:46 AM
SC-S2000's Avatar
its an ACT Clutch and i highly doubt its the diff because the noise is made while i am sitting still.
Old Jan 19, 2006 | 12:27 PM
profpin's Avatar
this sounds like the pressureplate bolts came loose on you.. this is just from my experience...
Old Jan 19, 2006 | 12:33 PM
SC-S2000's Avatar
im hoping its something like that because if its install i am gonna get money back from the shop that did it if not i will try to get ACT to replace it. As long as its not the friction plate.
Old Jan 19, 2006 | 12:34 PM
SC-S2000's Avatar
and while im on the clutch topic any body have any opinions on changing the flywheel good bad or no big difference.
Old Jan 19, 2006 | 12:51 PM
vtec9's Avatar
lightened and balanced flywheel will give you better response.. RPMs will rise faster (less mass to turn) = get to vtec faster = faster accel
Old Jan 19, 2006 | 01:23 PM
cdelena's Avatar
That noise is probably your stripped pinion gear flapping against the ring gear.. Why else do you think you can make it in any gear sitting still.
It would be wise to listen to the noise with the door open to be sure it is in front of you and not behind you before you decide to drop the transmission.
Old Jan 19, 2006 | 04:36 PM
SC-S2000's Avatar
update
got the trans out clutch is in good shape but the trans is not something around the input shaft is broken.
anyone have any ideas on where to take it to get it fixed or any parts that can be used to strengthen the trans. or if need be any trans donor vehicles that would be a direct bolt in that are built any stronger.
Old Jan 19, 2006 | 06:22 PM
profpin's Avatar
cant help you without no pics..
