Trunk fits incorrectly, what could be causing it?
Old 02-02-2024, 09:26 AM
Lloyd11's Avatar
Default Trunk fits incorrectly, what could be causing it?
Hi y’all, the right side of my trunk (pic below) is completely fine
however the left side (pic below) does not and sticks up slightly
i am able to push the trunk down with my hands to where it should be. What should I be looking at to see why it’s not fitting correctly? (Note: this car has not had a wing)
Old 02-02-2024, 11:13 AM
windhund116's Avatar
Received 1,452 Likes on 974 Posts
Did the car get into an accident and the quarter panel was replaced?
Thanks!
Old 02-02-2024, 12:00 PM
Lloyd11's Avatar
Thanks!
no, not to my knowledge
Old 02-03-2024, 05:45 PM
rrounds's Avatar
Did the wind ever slam the trunk open? That could put a twist in it. Or close the trunk with something hitting the left side of the trunk.
Rod
windhund116 (02-03-2024)
Old 02-04-2024, 04:30 AM
Chuck S's Avatar
Received 1,147 Likes on 1,009 Posts
Tried twisting it counter-clockwise? Seems to be all that's necessary.
-- Chuck
Old 02-04-2024, 10:15 AM
cosmomiller's Avatar
Received 1,572 Likes on 936 Posts
It could have happened if the lid was forced closed on an object sticking up from the trunk. May be able to counter that force gently and until it fits again.
Old 02-04-2024, 02:18 PM
B serious's Avatar
Received 1,283 Likes on 964 Posts
Someone may have slammed the trunk on an object or put a bike rack on it. Sometimes bike racks have straps that pull up on the panel in order to secure the rack.
Check underneath if there's something obstructing it.
Its not a common "S2000 thing". So, anything that could have caused it on a regular car could have caused it on yours.
Old 02-06-2024, 04:57 PM
Lloyd11's Avatar
-- Chuck
how would you recommend I go about that to do it properly? Also I noticed the left rubber stopper was angled backwards. Do you think it’s possible that with it being closed like that it could have bent over time?
windhund116 (02-06-2024)
Old 02-06-2024, 06:54 PM
Just out of curiosity, how often are you opening and closing your trunk?
Thanks!
Old 02-07-2024, 02:36 AM
masymas's Avatar
Former body man here. Try to screw the left side rubber stopper in a turn or two. That will lower the closed height.
windhund116 (02-07-2024)
Quick Reply: Trunk fits incorrectly, what could be causing it?
