tsb 00-055
Old Aug 5, 2005 | 10:26 PM
andersayz's Avatar
Default tsb 00-055
if i understand correctly, if you want this problem fixed on ur s2, you print out this tsb and show it to a honda dealer/mechanic and it should be covered under warranty. since the service bulletin is for the MY00, will it work for a MY02 in anyway? because i've been having this problem, and i know i havnt been mis-shifting.
Old Aug 5, 2005 | 11:20 PM
RACER's Avatar
TSB stand's for technical service bulletin. A TSB is NOT a recall, and therefore, Honda will not honor a TSB unless you can demonstrate the problem before them.
Unfortunately, sometime's a problem won't surface when the tech ride's with you.
Old Aug 6, 2005 | 06:29 AM
Slows2k's Avatar
If your car isn't the same year as the TSB, it doesn't apply. Your car still may have a screwed synchro, and a similar repair to the TSB.
Wormiez
Oct 8, 2006 10:41 PM
#22Benny
Mar 12, 2004 09:22 AM
50cent
Dec 15, 2003 09:36 AM
Blue Bitch 2K
Feb 8, 2003 08:31 PM
THRILLR
Apr 24, 2002 02:56 PM
