tsb 00-055
if i understand correctly, if you want this problem fixed on ur s2, you print out this tsb and show it to a honda dealer/mechanic and it should be covered under warranty. since the service bulletin is for the MY00, will it work for a MY02 in anyway? because i've been having this problem, and i know i havnt been mis-shifting.
TSB stand's for technical service bulletin. A TSB is NOT a recall, and therefore, Honda will not honor a TSB unless you can demonstrate the problem before them.
Unfortunately, sometime's a problem won't surface when the tech ride's with you.
