Turbo back to stock
Old Jun 16, 2010 | 02:17 PM
curve030303's Avatar
Default Turbo back to stock
I believe that i am taking my turbo set up off along with my aem standalone and putting it back to stock with an ecu. Is their anything that i should worry about by doing this?
Old Jun 16, 2010 | 02:31 PM
crank's Avatar
if its done right, nope !! make sure your using the ecu that is matched to your key !
Old Jun 16, 2010 | 02:35 PM
how about if the ecu is different from my key? because the ecu i would be using comes from a different car..
Old Jun 16, 2010 | 03:01 PM
crank's Avatar
you would HAVE to get it reprogrammed to match the key, US spec cars have an imbilizer.....if you dont do it the car will NOT start. sorry for yelling
Old Jun 16, 2010 | 03:14 PM
josh7owens's Avatar
your car is going to feel so slow
Old Jun 16, 2010 | 03:15 PM
240toS2k's Avatar
Yup, take it to a dealer and they should be able to either program your key for ecu or vice versa.
Old Jun 16, 2010 | 08:15 PM
Oh alright.. Do you guys know about how much that would cost? Also would i just take them my key and just the ecu or what?? i mean the ecu is small and the key is just normal so how would that work?
Old Jun 16, 2010 | 08:22 PM
240toS2k's Avatar
IIRC the key's code is added to to the ECU. They might have to do it with the ECU in the car but I'm not 100% sure on that. The biggest concern for the dealer would probably be to make sure you didn't steal the anything.
Old Jun 16, 2010 | 08:41 PM
i wonder what would be the best way to go about things then.. i mean i will have a receipt from a shop showing i bought it; if i go with them.. But i mean i guess the best thing would be just to call and see what they say.. any one else have any more info on this
thanks for the help 240tos2k
Old Jun 17, 2010 | 10:14 AM
03_BB_S2K's Avatar
All i can say is that a car never goes back to how it should be when a turbo set up is removed unless it's extremely well retuned. Good luck
