turn signal woes
Old Feb 12, 2007 | 02:06 PM
JS2k.com's Avatar
Sponsor
Default turn signal woes
Okay I tried to put in led rear turn signals and didn't go very well. I tried them with the hazard switch and blew the hazard fuse. I replaced it and the hazards work but only for the front and side signals. Now I only put the LED bulb in the left rear socket, but neither signal will work. I checked the ''turn lights'' fuse, and it was not blown.
Is the ''turn lights'' fuse the same as turn signal fuse?
Any suggestions? thanks.
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
Old Feb 12, 2007 | 03:04 PM
s2kBryan916's Avatar
It would be hard to diagnose tricky electrical issues over the forums.
If fuses check out ok?
Do the fronts blink when you use the turn on the steering wheel?
Old Feb 12, 2007 | 04:04 PM
JS2k.com's Avatar
Sponsor
Yes, th only ones that don't are the rears.
__________________
_________
Old Feb 12, 2007 | 04:12 PM
SheDrivesIt's Avatar
Do the rears work when you replace the original bulbs?
Old Feb 12, 2007 | 06:43 PM
JS2k.com's Avatar
Sponsor
Sorry, I replaced the OEM bulbs when testing it last, which do not work.
__________________
_________
Old Feb 13, 2007 | 07:12 AM
JS2k.com's Avatar
Sponsor
I'm going to check the fuses today, but I may have done some damage because there were exposed wires. Last time in my RSX I blew the backup fuse when I had exposed wires touch.
__________________
_________
Old Feb 13, 2007 | 05:17 PM
JS2k.com's Avatar
Sponsor
Is there any place other than the dealership that can diagnose electrical problems or am I stuck being raped?
__________________
_________
Old Feb 13, 2007 | 05:38 PM
Slows2k's Avatar
Lets see, you screwed up your own car trying to wire in LED bulbs, and you don't know how to fix it.
Sorry, looks like you'll be paying someone to fix your mistake.
Old Feb 14, 2007 | 11:18 AM
JS2k.com's Avatar
Sponsor
damn, that's what I was afraid of.
__________________
_________
lopez14
Jul 15, 2013 03:41 PM
wiley_s2k
May 11, 2012 02:13 AM
AROD
May 29, 2007 02:37 PM
PLYRS 3
Jun 25, 2006 07:46 PM
JohnnyCat
Nov 15, 2002 06:26 AM
