Typical 4 cylinder missfire question
Old May 31, 2015 | 03:16 AM
jfitz's Avatar
Default Typical 4 cylinder missfire question
Bought a AP1 the other week when I was test driving it it was running fine. Got it home and engine managment light came on.
A friend came and pulled the codes and it was the 4 cylinder misfire and random misfire bunch.
The timing chain was a little loud so I took the TCT out and gave it a refurb which got rid of the noise. But I have a engine managment light on constantly and every now and then when I stop and say traffic lights when its on ideal the light will flash at me, and as soon as I bring on the revs it will stop. I have read that is because maybe its misfiring and damaging the CAT.
I can feel the car running a bit lumpy on ideal other then that it sounds and runs great. I took it to Honda and they tried throwing a £2000 bill at me for doing the TCT as they said to do that they would have to strip it down and might as well do the timing chain to.... so I asked for my keys back.
Its had new spark plugs, a oil change, TCT refurb, and I'm going to do a valve adjustment as soon as my gauges arrive.
I have heard lots of people saying about coil packs which I don't really know how to check and people saying about all sorts of sensores that I don't know where they are lol I'm no mechanic but want to do it myself and can get help from some friends.
I have had to drive the car a lot which isn't ideal but it hasn't been a problem at all.
Can anyone give me any tips without confusing me to much lol its done 80,000 miles don't smoke at all, burns no oil and is in bloody good condition so i really wanted to get it up and running
Thanks
Old May 31, 2015 | 04:21 AM
SouthDakotaS2K's Avatar
As long as the misfiring is not constant and the service engine light is not flashing you should not damage the cat. If it were my car I would do the valve adjustment first. Then check the compression. If that is all in order then I would move on to the other misfire causes which seem to be either coils or injectors.
Old May 31, 2015 | 04:34 AM
jfitz's Avatar
I did also run some injector cleaner through it as advised by previous posts but no difference. My next job is the valve adjustment for sure as ether way I want to do that.
Thanks for the reply
Old May 31, 2015 | 08:23 AM
For what it's worth my '00 was making some popping noises in the exhaust at idle and even set the check engine light once. I sent the injectors in and had them ultrasonic cleaned and flow tested. After reinstalling them I have had no issues (3 years ago). It's not gonna work for everyone, but it worked for me.
Old Jun 2, 2015 | 09:29 AM
CoolGuy094's Avatar
I too have experienced a random misfire which was eventually solved by sending the injectors out to be cleaned.
If the misfire were just on cyl 4 constantly then you could try the trick of swapping the coil pack or injector from #4 over to a different cylinder and seeing if the misfire code follows the swapped component. If it does, then that component is faulty. If it doesn't, then you may have an internal issue like a valve problem, or it could be wiring to the coil or injector.
v_I_etn_AM_ese
Feb 9, 2009 01:39 PM
WI4FEN
Sep 6, 2007 01:59 PM
lilbizzyazn
Sep 20, 2005 08:16 AM
michaelg
Mar 10, 2003 12:32 AM
supwithyou
Mar 9, 2003 09:10 PM
