Urgent help please
Old Sep 30, 2006 | 09:28 AM
NEODYMIUM's Avatar
Default Urgent help please
My brother has put off emmisions to the last minute. The emissions facility reported a bad O2 sensor. After it is repaired, will the car clear the code itself? Or does the ecu need to be reset? If it is reset and then retested immediately it will fail correct? He's got 33 minutes til no license
thanks
Old Sep 30, 2006 | 10:19 AM
cdelena's Avatar
Even if it is cleared it will be remembered by the ECU for a number of cycles. Most states require the code to be cycled out of the stack before passing the test. Last one I fooled with (not the S2000) it took 50 miles of driving before it would pass on the inspection computer.
Old Sep 30, 2006 | 03:28 PM
Ek9's Avatar
Ek9
Banned
His only choice is to drive it illegally until it's in "Readyness" which means the ECU has tested and verified the emissions are OK. Just because it has an O2 code, that doesn't mean it has a bad O2 sensor.
Old Sep 30, 2006 | 06:05 PM
Slows2k's Avatar
Being that the 1st reply wasn't until after your 33 minute deadline, I'm guessing you guys figured it out?
Pacman123
Oct 5, 2016 06:01 PM
EOE
May 30, 2016 11:43 AM
H2kBBAP2
Oct 11, 2010 07:13 PM
Fredster
Sep 15, 2009 05:13 PM
cdelena
Dec 17, 2002 05:11 PM
