USDM vs. JDM Engine Question
Other than the pistons, which are higher comp. in the JDM engine, is everything else identical between the 2 engines?
I'm primarily interested in the valves, valve clearances, and the cams in the USDM engine vs. the JDM engine.
As always, any info is greatly appreciated! Thanks in advance!!
Originally posted by RWD_RCKT
If I am not mistaken I think just the head gasket is different... JDM gets another 0.7 points of compression from that... not the pistons.
The head is identical.
Originally posted by Shamu
Hmmm...I've actually heard the exact opposite -- that the additional 0.7 points of compression comes from the pistons and not simply with the gasket.
I understand that the ECU cannot change compression, but I'm wondering if the JDM ECU adjusts for the higher compression of the JDM engine? For example, gives more fuel to ensure the JDM engine doesn't run too lean?
I've confimed that the 0.7 increase in compression in the JDM engines is not caused by the gasket, but the pistons. The JDM pistons are higher compression than the USDM pistons.
Cheese and Onion
Apr 28, 2009 05:49 PM
allenheathdj
Jan 23, 2004 10:05 AM
